My Engine (2GM20F) was working fine before I decided to change both the primary (Racor) and secondary filters (1st time since I got the boat 2 years ago). Now it won’t even start. After changing both filters I bleed the system from the secondary filter using a bulb attached just before the racor filter, then I started the engine and ran it for an hour with no problem. Next day when I tried starting the engine, it would run for about 10 second then shut off. I checked the system and noticed the racor water separator bowl was almost empty. I realize the water separator valve was leaking so I replaced the whole racor water separator unit. Now I have no leak. I bleed the system again from the secondary filter and I tried bleeding it from the top of the injector, but no fuel came out and the engine would not start. Can someone tell me what’s wrong?
Regards
Salty
Regards
Salty
