Engine wiring
Raymond Wulff
We at The Waterfront Center have received a 1984 catalina 30 as a donation. We are a nonprofit organization and want to use the boat as part of our school programs. The engine wiring needs to be redone It has a three cylinder universal diesel engine. A wiring diagram of the engine and it's control panel as built would be very useful. Any information you could provide would be most helpful. Thank you Ray Wulff
Jun 4, 2004
1
- - little rock, ar
Wiring
Ray, I think that the Catalina yachts customer service department would be a good place to start. Also, Seward Products in Whittier, CA. has been the longtime Catalina supplier of engine panels and wiring harnesses. They should be able to help you with wiring needs, too. Seaward's number is 562-699-7997
Feb 12, 2004
85
- - Stingray Point, Va
wiring diagram
http://www.catalina27.org/Tech/harness4.gif This should be a good start. They use the same harness on all the universal diesels.
Wiring Harness
In addition to Ken's great reference, try this: http://www.catalina27.org/Tech/harness.htm Stu
