Check the fuel filters
Both the primary and secondary. If the bowls aren't tight or the set screws are loose, you'll have fuel galore but it won't be obvious to look at either. Just don't overtighten the set screws or you'll strip the threads. Why the fuel pump housing is made out of soft aluminum is a mystery to me. Probably dreamed up by a boat-hating golfer.
