A little background. I recently changed our prop - a folding 2 blade - to a Campbell Sailor 3-blade; 14x8. Goodness, it feels like a different boat (well, I guess it is sorta). 20GM20F by the way. Very smooth and with a lot more bite in reverse but here's the issue.
While taking the new prop out for a test run, I recorded boat speed vs RPM and was pretty happy. I had pushed it to 3400 for a couple of minutes after some steady runs at 2900-3000; generating some extra smoke. Next time out; with the engine thoroughly warm and after running at 2900 for 20 minutes I decided to check to see what max RPM would be. I eased it up to ~3400 for a minute then pushed the throttle to max. Well, it did not get any faster so I thought, "I guess max is 3400 and that is still OK". Just then, the RPM started to slowly drop so I pulled the throttle back to 2800 and it ran with no issues. From that point on however, I cannot get above 3000 RPM. Discussions with some old heads around the docks suggested that I might have clogged filters which made sense in light of the stumbles I experienced the next time out. With that in mind, I replaced the primary and secondary filters (see other thread). Well, she runs beautifully now; starts easily, runs smoothly and doesn't smoke very much but I still cannot get above 3100.
What do you guys think? Remember, this happened fairly suddenly. Could the tach be off? Isn't it controlled by the alternator? Could I have lost compression even if it runs well? Could I have dislodged some crap in the elbow and am now getting an exhaust restriction?
TIA everyone.
Clark
TIA everyone.
Clark
