Herman, before you simply clean out what you have, consider this solution.
Since it looks like you have the one-piece strainer/thru-hull that is pictured in Ed's post, I can attest that this type of strainer is a real pain to clean from either inside or outside. I had the same type of thru-hull on my A/C pick-up.
My solution was to replace the thru-hull with a standard unit and then install a separate screen with a hinged cover on the outside. The cover can be opened to gain clear access to the thru-hull by pulling a pin.
The pictures below show my original one-piece thru-hull with lots of growth inside of it. The second and third pictures show the new thru-hull with the hinged cover screen open and then in the closed position.
Going forward, maintenance is a snap.
