Hi all,
I have a question about engine starting and batteries. First my Endeavour has a Yanmar 2QM20H. I have two marine batteries connected to a selector switch. My plan was to use battery one as the starting battery and battery two as the house battery. That way I don't run the starting battery down with lights and stuff. Both batteries were charged and the charger showed 100% charge. The test switch shows both batteries as fully charged. Here is the issue or possible issue. When trying to start the engine, I need to have the selector switch on both for the engine to turn over fast enough to start the engine. Just one battery won't work. Is this normal? Is my battery not strong enough? I am planning on testing each cell with an tester, to be sure I don't have a dead cell, but I thought I would post the question, to see if I really need to use both batteries to turn this engine over.
Thanks,
Mike
Thanks,
Mike
