Engine Soundproofing
Tom Heiting
Has anyone found a cheaper alternative for engine compartment soundproofing than the expensive foil/lead foam sheets?
mrbill
maybe 4'x8' insulation w/ foil outer layer
Home depot sells various thickness, (1/4"-3/4") sheets of insulation (4'x8'). it has a foil outerlayer, and is closed cell. BUT, no idea if it is fireproof... or what gas/diesel/oil will do. take a look next time at HD.. found in lumber dept. but its cheap
F
Fred Ficarra
Sorry mrbill, not for engine rooms
It'll not work well in an engine room where you want to dampen sound. I used the stuff around my freezer. Use the lined/leaded foam for sound dampening.
