Engine rust and sticking screws
Jared
I have a few questions for the folks that know much more about engines that I do... 1. I was trying to change out the raw water impeller and I took it off the engine block, but the screws that held the pump cover on seems locked onto the pump pretty well. As I tried to get them off, it seemed that they wanted to strip the head before wanting to loosen. I sprayed them with WD-40 to no avail. Is there a way to get them off - should I try using my cordless drill with more torque and just hope for the best. If I strip the heads, how can I get the screws off without having to replace the pump? 2. If there are small areas of rust on the engine, should I hit them with a wire brush and sand and paint over? Is there a special engine paint and if so, where can you get it? Do some people just leave it - I would rather have everything looking ship-shape though. Thanks for any suggestions.
Jun 7, 2004
944
Birch Bay Washington
A little Coke or pepsi
is supposed to work for loosening rusted bolts. Soft drinks are toxic and hazardous though so be careful and make sure to get a permit. You could also heat them a little with a torch. Don't overdo it and burn your boat.
Jun 2, 2004
257
- - long island,ny
Don't
Don't use a drill,try putting heavy screw driver on them and hitting with hammar or vise grips if you strip the heads. I coat my pump with anti corrosion spray every year when I take it apart and check impeller,when you do get the screws out try to replace with stainless screws. nick
Dec 2, 2003
210
Hunter 34 Forked River, NJ
Try this
I can get my vise grip pliers on the heads of the screws easily, if the pump you have is a yanmar, you should be able to do this too! Buy a new set of screws, and use never seize on them, makes it easier to remove them next time.
Timbo3
Sep 11, 2004
70
Hunter 30_88-94 Tarpon Springs, FL
allen heads
I replaced the screws on my water pump with stainless allen heads. Get the largest allen size you can and use good allen keys that fit tight. Ace Hardware.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
After I bought my boat...
...I removed as many bolts on the engine as I could get at(one at a time) and coated them in copper anti seize compound (except head bolts). Did the same with the outboard engine. To this day, everything comes apart so easily. Using Vise-Grips on the small screws of the water pump cover could well shear them off. Heat can be used very judicously. Overheating the pump can destroy the seals. But you may be reduced to buy a new pump if all else fails.
