Is it normal to lose RPM'S over time. I have an 89 Cat 30 with a Universal M25XP with around 900 hours. I never go over 165 degrees, and I can easily hit 3200 RPM'S at the dock (not in gear). I noticed while motoring over from my winter yard that under power and in gear I was maxed out at around 2600 RPM'S. I will swear that last year I maxed out closer to 3000. The bottom is as clean as it can be (new paint). The prop has not been changed and is the standard 2 blade fixed. Is the engine losing compression? Is there a problem with the transmission?
