Because....
I changed props on the boat and shortly there after my RPM's dropped quite a bit. The prop manufacturer said he had put the same prop on the same boat with a much, much smaller drop in rpm's. He will be happy to adjust the prop, but he wants to make sure that the tach is accurate... The reason we have any doubt in the first place is because when the engine reaches it's max rpm of about 3200 (it is rated and used to do 3800 underway) It doesn't seem to be loading up (no black smoke) when the throttle is advanced further. (the throttle is advancing to the stop on the engine itself, and will advance normally when not under load) There was a span of about 2 weeks from running the boat with the old prop and running with the new prop.. I doubt that anything would have changed with the engine during that time, but I went ahead and changed filters etc to be sure, but no luck...Some options are having a diver take off the new prop, put on the old one, run it and see if it spools up like before, or getting a some sort of verification of my engine rpm's...Hence the question.I would bet the boat (not really) that the prop is over pitched, but the lack of black smoke has me at a loss..Thanks,Brian
