Note: RPM gauge not working.
I've been beating my brain out on this one. Two weeks ago I noticed that I could only go 5.5 knots when my cruising speed is more like 6+ and max 7 knots under power. I didn't have my knot meter in so thought maybe I was in current. Later I thought...nope...not in a current so then I started wondering if I forgot to put my zincs on last year and my prop was degrading or maybe my prop was covered in barnicles.
Last weekend I dove and saw that the zincs where still there and prop was good and didn't have many barnicles on it but I cleaned it anyway.
This weekend I could only get 4.5 knots and had the knot meter transducer in the water to verify I wasn't in a current and it sounded like the engine wouldn't increase RPM as I pushed the throtle after about halfway. So then I thought maybe my fuel filters (both primary and secondary) were clogged so I replaced them and yes, they were nasty. Figured I solved the problem while at anchor, but the trip home proved to be it to be wrong.
So, filters aren't the problem. Prop not the problem. Fuel supply not the problem.
Possibles I can think of: linkage from throtle to engine, bad fuel (I think the filllup before Saturday was bad fuel so 1/3 of my tank now may be bad) maybe partially clogged injectors. Other ideas?
