engine revoval
rob
how long should it take to remove my yanmar yse12 from a 1976 hunter 30? any tips? thanks
H
Henry Weber
Yanmar engine removal
Rob The time it takes is dependent on your tools (lifting device) and on the level of corrosion (difficulty) around the exhaust manifold and prop shaft couplers and engine mounts. I have removed the YSB12 from the 1977 H30 several times. If there are no delays from the above areas, it should not require more than 1 to 2 hours to remove the engine. On the other hand, the first time the rust was so bad it took the better part of a day. What works best for me is to slide the engine into the salon using plywood pieces and a few 2x4 blocks cut to fit. Then I use a davit on the seawall to hoist out the engine. If you leave the accessories on the engine it can be a tight fit getting it out into the salon, For this reason I removed the water pump and I think also the exhaust assembly. Maybe also the alternator and starter. Installation is much slower because of the engine alignment requirements. For hoisting I have also used the main halyard but the winch is a bit puny. Have fun. Henry
