Greetings all. I am about to pull the engine on my 1985 Catalina 30 for a complete overall. My question is, how to you separate the shaft coupling from the transmission? I removed the four bolts and I noticed 2 set screws on the shaft. Do I need to remove these also? I have read several threads on this topic but I am still unclear on how to separate the two. Does the prop shaft slide back to allow for engine removal? Any thoughts would be grateful. Attached is a photo of what I am looking at. The boat is in the water and the last thing I need is water coming in if I screwing something up.
