Occassional spitting & splatting is normal
Charlie,I have a '74 O'Day 27 with 13 hp Volvo diesel. You are right about the mixing of exhaust and water sputtering out as it is pushed over the loop. It doesn't take much water to cool the engine (I'm not sure if this is true about gas engines). However, I have had an occasional blockage in the intake line.Here's what my neighbor taught me to do.1 Check the size of your rubber line going into the water pump and buy the same size female end connector for a garden hose.2 Disconnect the line going into the water pump and push the garden hose connector into it. 3 Connect to a garden hose and hold it while someone turns on the water.I like to have air in the garden hose so that I can hear it bubbling up outside the hull.Please note that I have a Volvo saildrive unit, but this should work for you, because my neighbor has a regular drive unit. It is cheap, easy and effective.Congratulations on your new baby.Jim Cook"Dream Chaser", O'Day 27
