K
Kevin
I was having a problem with my Yammar diesel overheating while on the upper end of its RPM range. After countless trys to correct this problem (thinking it was prop related) it turns out that my Heat exchanger was clogged. I used a product called TRAC barnacle buster which I circulated through my heat exchanger for a couple of hours. it cleaned out the entire system while still on the engine! I would recommend this product to anyone having the same problem. I plan to use it once a year.
