I thought I had found the culprit of my overheating blues. I can run all day at 2500rpms but over 2800 rpms, a little wind on the nose, pull a dinghy and my high temp alarm was going off.
I finally decided to crack open the front end of the heat exchanger (HX) to see if I noticed any blockage. Right after I pulled the hose off the front end I thought I could see something didn't look right. I couldn't pull anything out with needle nose pliers so I removed the front cap of the HX-sure enough, there was the vain of an old impeller-how old I don't know, could have been the previous owner. I removed the vane, replace the cap and fired it up. (see pics)
A test run at the dock running at 3000 rpm and tied in the slip for 4 minutes indicated no over heating, all seemed good....but the engine still sounded very hollow (waterless) at the higher RPM. At the low rpm there is still a nice "swish-bubble-goosh".
Stay tuned...
Stay tuned...
