The engine overheat horn sounds a lot, and the engine does not appear to be hot. The boat is a 30' 1981 Hunter and the engine is a Yanmar 2Q15. The water comes through the petcock o.k., I cleaned the strainer, removed the water pump and the impeller is o.k. Is there some sort of sensor that might be bad, causing the horn to sound when the engine is not really hot? I normally run the engine at 2200 to 2300 rpm, but this week the horn sounded when I was running at only 1800 rpm. Finally, I had a diesel mechanic check it recently, he cleaned the injectors, adusted the valves, etc., but that didn't help the horn sounding problem. I would appreciate any comments or suggestions. King Elliott, "King Louie", Miami, FL BB2F
