Might be a good time to inspect/ replace the impeller if it has been in there for awhile.
Patrick
________________________________
To:
AlbinVega@yahoogroups.com
Sent: Thursday, April 30, 2009 6:51:50 AM
Subject: Re: [AlbinVega] Engine Ops CheckA diesel mechanic told me any impeller worth its salt will run dry for 30 seconds or a minute or more, no harm done.
(Although I usually grease mine when reinserting it, just for form.)
Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
Sent: Thursday, April 30, 2009 9:41 AM
To: AlbinVega@yahoogrou ps.com
I have run the engine with the boat on the hard by doing as you say with a
hose.
Very straightforward.
I did it to run antifreeze through the engine & exhaust.
I also did the same when the boat was in the water - during the very cold
weather back in January/February - again to run antifreeze through the
system.
Only negative maybe is that impellor is spinning dry at first but you
could prime the system by connecting the input pipe directly to the water
pump and raising the bucket/barrel so that there is a "head" of coolant...
John
V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@ ul.ie
University of Limerick FAX: +353-61-334927
IRELAND Web:
http://jkcray. maths.ul. ie
