Yes it looks like they are showing the MD2b engine Yours I believe is an MD2A. I think the MD2B is Volvo Penta and the MD2A is just Volvo. Not sure about this but the one they are showing is not your engine. My set of drawings show that the MD6A has an "o" ring and that the MD7A does not.The MD7A does not have a hole in the bottom but instead has a hose fitting so water leaking through the seals can be drained into the builge. So your pump should have an "O"ring. Now, it is possible somebody may have replaced the pump housing with one for an MD7A. If they did there will be no hole but the hose fitting instead. The earlier engine that needs the O ring is your engine. Doug
Douglas Pollard Dougpol2@...
On Sat, 10 Aug 2013 15:35:43 -0000
