Hi,
Today, when I checked the oil level in my MD6A,
it looked like a grey emulsion.
The day before it looked perfect, and it actually
was changed very recently.
I assume this emulsion likely means water in the oil.
Is that correct ?
Yesterday I had three not so typical situations:
- The engine was abruptly set to full backward,
when a rope catched the lever in the cockpit
(and I was busy with the sail close to the mast).
After some seconds, maybe a minute, the engine stopped by itself.
It did not want to start in the beginning,
but after a few minutes it was back to normal.
- I had to run the engine at almost full speed backward for a minute,
to get out of a rock.
- I was sailing for a few hours with large heels, 30 degrees,
and rather big waves. The engine was of course stopped.
Could any of this situation be related to the problem?
If it is water in the engine, could it come via the exhaust?
It is not a typical Vega "dry" exhaust.
Water mixes with exhaust gases rather close to the engine.
See the photo:
http://www.albinvega.pl/wp-content/gallery/techniczne/lotta_exhaust.jpg
Perhaps it is a bad design?
I use however this setup for seven years now, with no problem so far.
I've changed today the oil, and then had to run the engine for 1 hour,
It worked normally. The oil looks gold-fresh.
I am anyway going to change the oil again as soon as I get new oil,
i.e. probably in the next harbour.
Any ideas?
I am now cruising Swedish Baltic archipelagos,
still quite far away from home, which is on the other
side of Baltic, close to Gda?sk.
Cheers,
Marcin
V1958 "Lotta"
Is that correct ?
See the photo:
Any ideas?
Cheers,
Marcin
V1958 "Lotta"
