Shabby
Few questions: green oil? Is that coolant? Oil even shortly after an oil change will be a dark brown/black. Are the 'green drops' near the water pump or hoses?
If the engine was recently serviced, the couple of drops of oil could be from the oil change or filter removal.
I would clean up any residue and place an oil blanket in the fiberglass pan. If you continue to get drops of oil then you should figure out the source. Could be something as simple as a loose sensor or an indicator of a bigger problem.
