After a looooong repair from Sandy Damage, Hallie Luna finally splashed July 4th weekend. Since the yard did not winterize the engine, they would not start it. So, new batteries installed etc..... I threw the key in, turned the switch, waited for about 20 seconds, them pushed the "push to start" button. It was frozen. I sprayed a little pb blaster on it and it moved. So I did the hole routine again. When I hit the button to start the engine, I got nothing.....no clicking, no engine cranking, nothing. So after checking the posts on this site, I changed the push to start button....nothing. I cleaned the terminals on the ignition switch, cleaned all connections on solenoid and tried again. This time I got a click or two then nothing. The alarm doesn't even sound anymore. Then I realized that the battery that I had selected was down to about 2.5 volts
! Something is very wrong here. Any thoughts? Unfortunately I am not to handy with electrical.
Thanks in advance!
Hal
Thanks in advance!
Hal
