find a lagger
Dan do have you hear of armaflex?or ridgid board fiberglass? if not check out a commercial industrial insulation supply contractor.the armaflex is mainly used in cool temp. useage but as long as theres no engine fires it will probably be alright. it's easily applied with a armaflex glue somewhat like contact cement. it comes in different thickness from 1/2" thur 2" that I know of. I have used it on my boat which is a single cylinder diesel { quite noisey I might add }and it has worked very well.if your worried about heat,,,, check out the board glass. you can also get some stick pins and washers from the supplier. quite easy the application. If you are having a tough time finding the supplier try a commercial industrial insulation company. chances they won't want to help because of the profit margin {if any}but if you know anyone in costruction carpender plumber electrican ask them if they have seen or know of a {lagger} insulator, he might help .it's too bad your not closer I could help you get the insulation and would probably help you do it. But try to find the insulation contractor SUPPLIER he has the stuff and will tell you how to apply it. O K, D. good luck Jake the lucky lagger
