Engine mount supports
6
Pearson386 38 Ann Arbor/Trinidad
Does anyone have knowledge about what kind of support is under the engine mounts? Is there any metal or is it wood. We are thinking of re-powering and the mechanic would prefer to have a more robust support. We are not sure if there are lag bolts or what?
Ariel
Feb 1, 2006
279
Pearson 36-2 Houston, TX / Rock Hall, MD
If I remember correctly the engine mounts were on the two main longitudinal hull stiffeners. These were about 3/8 inch thick fiberglass and were hollow. The bolts or screws to hold the mounts were threaded into them. I would drill a small hole into the beam to be sure they are glass or if they have a wood beam internally.
Dave
s/v ARIEL
Apr 12, 2012
6
Thanks Dave, the mechanic would really like to have some metal in there for support. If it's not in the fiberglas he will add an extra plate on top.
