K
Keith
I need to replace the engine mounts for the SB 8 Yanmar, and am seeking advice on where to find them and whether there are "standard" sizes (Boat US carries a range of mounts; has anyone used Boat US mounts?)Also, are there different mounts for the front and back? The front mounts have a nut above and below the mounting bracket (making it possible to remove the top nut) while the rear mounts don't have the nut on the bottom (making it impossible to remove the top nut). Needless to say, the nuts are very rusted and the Dremmel tool looks like the only removal option.I also want to install a flexible coupling and would like to hear of others' experience with using them.Thanks for your advice.
