I've been playing around with the Noland Engineering Engine Data Converter http://www.nolandeng.com/rs11.php. Model is RS11 and costs $230. This is the cheapest engine monitor for Nmea2000 systems that I have seen.
It is reletivly easy to setup via its RS232 interface and WinXp Software.
I simulated the various sensor inputs and you can see that in the attached photo. I hooked it up to my Garmin 720 chartplotter. They say you should have guages already present but as long as there is voltage to the sensor you should be OK.
You get 4 analog inputs and 2 tach inputs.
Now I have to see how to attach the various senors to a 3GM30F while still leaving the alarm sensors.
Another project
Another project
