H
Henry Weber
My YSB-12 (1300hrs) on Hunter 30 starts easily and is reliable. But two days ago it was hard to start. Required 10 sec. of cranking and then barely got going. It appeared to run okay with normal power after it started. Next day after sitting overnight engine locked up solid when I tried to crank. 2nd try same thing. Opened compression release and it cranked okay. Then with release closed, it cranked but started only with great difficulty. When running I did not see any unusual signs such as white or blue smoke. Oil pressure normal,temp normal, discharge water also normal. I would really appreciate any ideas as to what is going on. Thanks.Henry
