Engine lift
88
Macgregor 22 Lake Texoma Tx
What kind of lift do you use to lift your motor from the ground to the back of your boat ?
caguy
Sep 22, 2006
4,004
Mac 25 Just the arms and legs. On the C27 I put the tailgate under the bracket.
NorSea 27 Az., Doing the To-Do list
We used
our boom.
We swung out the old engine (photo below) to the finger dock, and just reversed it to get the new one in. Just make sure to tie the halyard or topping lift to the same area of the boom where you are putting the line to lift the engine.
We swapped out a Yanmar 2QM15 for a new 2GM20F
Greg
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Bend at the knees...Lift with your legs....
WayneH
Tartan 37 287 Pensacola, FL
Slow, Use a twenty year old. His back is strong and he won't complain later because then he'd be a wuss.
Otherwise, lower the motor mount. Back the truck under the boat with the engine in the bed. Lift the motor to the mount then tighten the motor clamps. Put a lock between the clamp handles and you're good to go.
LloydB
Jan 15, 2006
926
Macgregor 22 Silverton
Now I ask for help - two guys better than one with the heavy four stroke. Otherwise when there's no one at the ramp I've had to back up to a raised curb so that it was only pessary to lift the motor 18" sideways and 8" hi to get it from the hand truck to the boat. The first time I lowered the stern by taking it off the ball and lifting the bow with the trailer jack to get the stern down but it didn't work as well.
