Engine insulation replacement
Tim Op't Holt
The insulation around the inside the engine box has fallen apart. So, I'll replace it. Can anyone provide guidelines and what they used to do the same? I have some good advice from an article in PS.
Dan Geltmacher
Me too!
I also bought the insulation material from west marine. Cut to fit. Use a spray on adhesive to keep it in place while you tack it down. Job took about 1 hour. Getting the old stuff out was harder. I used a shop vac and a putty knife. Good luck. Dan S/V Illusions
