Engine Hours 2009 Hunter 50cc
Jun 22, 2020
3
Hunter 50cc Whitefish, MT
Hi. Could anyone tell me how to check the engine hours on my boat? I have a 2009 Hunter 50cc with the Yanmar TE i5501/5601 electronic screen. Version 2.07 shows on startup. I have gone through the manual and every key path. Are the engine hours available or should I add an hour meter? Thanks.
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Hours should be read in the tach face. We have a 2006 and the hour meter died about 5 years ago. A very common problem with Yanmar. If it is not then you will need to install an hour meter. Check the Hunter Owners Forum on this. Very common.
Jun 22, 2020
3
My boat doesn't have a separate tachometer. It has a Maetron Display with LCD screen from Yanmar. It can be programmed to view tach, oil pressure, water temp and fuel tank levels. It is all on NEMA 2000. I just cannot find how to view the engine hours or even if they are tracked on the system. I wish it had a manual tachometer and hour meter. Going to add at least an hour meter if I can't locate it on the system.
Jun 1, 2009
1,860
Hunter 49 toronto
Hook up the Maretron to your plotter. You should be doing this anyway, as the Maretron display is useless.
It will show you all your engine data, and you will love the result.
When I’m motoring, I run a split screen on my plotter, with chart vs engine.
That way I can watch my oil pressure & temp. Also nice to have tach & fuel
It you want info on how to do this, pm me.
Good luck!
  • Helpful
Likes: Ward H
May 24, 2004
7,202
CC 30 South Florida
Just add an analog hour meter at the key switch, they are rather inexpensive. I like gauges I can glance at and not having to look for them.
Jun 1, 2009
1,860
Hunter 49 toronto
This is going in the wrong direction.
He’s already got a N2K plotter at the helm, and the engine interface has N2K data.
Instead of installing a new guage, he has ALL his data right in front of him, and below at the nav station.
no holes to drill, probably cheaper, and a full featured solution.
I have never taken the cover off my Maretron since doing this. Don’t even know, or care, if it works..
Likes: Zencra
Dec 15, 2019
162
Hunter 49 San Diego
I agree with Art. Connect the Maretron to your MFD. Simple and cheap. I took his advice on my 49 and couldn't be happier.
Jun 1, 2009
1,860
Hunter 49 toronto
how do I connect the maretron to chartplotter? my maretron fuel guage has just stopped working and reading empty!
The fuel gauge is a totally separate entity
The tank has a resistive sensor which goes into one of the maretron plugs. If your display is reading empty, then I suspect the wire is broken, likely on top of the tank
With regards to connecting your maretron to your plotter, it’s all N2K plugs & cabling.
Very straight forward job.
Jun 15, 2012
717
BAVARIA C57 Greenport, NY
Connecting Maretron to chartplotter is great idea. I did it even before I knew Art! The hours however are definitely available on the Maretron display. Go to their website and download the manual. It will show you how to scroll through screens and display what you want.
Jun 1, 2009
1,860
Hunter 49 toronto
So, there was “life before Art”??
kbgunn
Sep 19, 2017
231
2005 Hunter 33 Lake Lewisville, TX
Your boat has a fiberglass arch versus the stainless arch.
Sailrite is the right spot for DIY. See this video:
