Engine Hour Meter
G
Guest
I purchased a 34' Hunter last year which has the original Yanmar 3 cylinder diesel. There was a hour meter installed at the nav station. Can anyone tell me how the meter should be hooked up and hour to test the meter ?
Sam Lust
Simple
An hour meter is nothing more than a digital count-up clock. It tells you how long your engine has been switched ON. Nothing more. Connect the positive terminal to the switched terminal of the engine switch. Use a meter to determine which terminal goes off with the key. The negative terminal connects to any convenient ground: usually, but not necessarily black. To test? hook it up to a battery and watch it. To make better use of your time you might make sure you have some varnish to watch drying at the same time.
