engine hot
1
2 1982 - 27 Dighton
I just replaced the water pump in my 1gm. (preventative maintenance existing one was leaking out the weep holes) boat ran fine with leaky pump and runs fine with new pump. However the engine block is hot.To hot to touch longer than 2 seconds. The oil filter is hot as well. The warning buzzer did not go off nor did the temp light go off and they are both working properly.I never really noticed the heat before and was wondering how hot the normal operating temperature is on the 1gm. Thanks for any input you may have.
Nov 6, 2006
10,256
Thermostat for that engine is (should be) 140 F.. roughly speaking, a normal person can hold a hand on something at about 120F and it starts being that ya have to take your hand off at about 135-140.. I think what you are discribing is normal.. The filter will get a good bit hotter after it runs a bit longer under load..
Oct 29, 2005
2,366
maybe air trap in hose when you replaced the impeller.
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
I think that you'd see some change in the color of the exhaust and/or a loss of power if it got too hot. Too hot would cause the air to rarify and starve the combustion - hence a loss of power and incomplete burn.
G
Guest
Temperature
FWIW, normal operating temperature for a diesel is around 190 degrees, too hot to the touch. It is safe to operate a diesel up to 240 degrees, but should be shut down immediately if it goes above.
Terry Cox
