I am moving my hot water heater to a new place under the V-berth. I am just wondering what kind of hose to use to extend the old lines to and from the engine to the heat exchanger in the hot water tank. The guy at West Marine said that most any kind of heater hose would be ok. I am not so sure about that. There must be some Coast Guard requirements.While I am at it, I am going to find out why this system has never worked in this boat (1992 Hunter 37.5 with a Yanmar 3HM35F engine). I can leave the dock with steaming hot water (electrically heated at the dock) and very soon, the water is much cooler if not cold.The existing system uses the secondary system from the engine to provide the water which goes to the hot water heat exchanger and then to an automotive type air heater. I am considering replumbing the main heat exchanger and sending the engine hot water which normally goes to that heat exchanger and instead sending it first to the hot water heat exchanger/air heater circuit in the bow. I must admit that I haven't recently looked at this stuff physically so am not sure about hose sizes, connections, etc.
