Engine for Roger
Ross
Jun 15, 2004
14,693
Probably about one horse power.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
A bunch of these
Around the New Orleans area. They virtually come crawling out of the woodwork every year at the wooden boat show.
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
It sounds like one of those hit and miss engines they used to use on farms.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
My young friend uses these to power a small train that he runs on discontinued tracks.
All U Get
All U Get
Sounds like a full scale model railroader's delight! Where does he do this, or is it "classified?" Got any pictures?
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
I think it's a Lister engine. They are well-suited to constant RPM, steady load sorts of applications like agricultural processes, power generation, and boat propulsion.
Get yours here. :)
The video would have been more impressive if the engine was under load instead of freewheeling.
Oct 2, 2008
3,811
Coos County which is NH Canadian border, I'll try to get some info and pics. I know his father has a collection of engines.
All U Get
Ross
Jun 15, 2004
14,693
We had one that powered a cement mixer when I was a kid. Only the exhaust valve had a lifter on it the intake valve had a weak spring that you held open when you cranked the flywheel. When it was spinning good you just let go of the intake valve and it was sucked open on the intake stroke and shut when the piston reached the bottom of the stroke. The flywheels pulled the crank through the compression stroke and the spark plug fired. There were grease cups on the rod and main bearings and I can't remember how the cylinder and piston were lubricated. The water jacket on the cylinder was open and we just added water when it got low.
Oct 2, 2008
3,811
Here you are, video and pics of the family and train club, also a quote from my friend.
"The engines were used for anything back in the day, from bailing hay to running water pumps to cement mixers in the twenties. Anything belt driven had one of them. The rail cars are a little different than the “hit and miss” engines, but are still one lung and crank engines. "
http://www.youtube.com/watch?v=crFrD2i5sC8http://www.youtube.com/watch?v=crFrD2i5sC8
All U Get
