E
Ernie Rodriguez
The thru hull for the engine exhaust hose on my H-36 (1982) is located such that when underway it is below the waterline, especially as the boat approaches hull speed. I am concerned that this increases the exhaust back pressure and results in a decrease in engine output. I have noticed that when underway under power, the bottom of the transum will be a good six inches in the water, while at rest it is a good two to three inches above the waterline. The thru hull for the exhaust hose is on the hull about six inches before the bottom of the transum, which places the exhaust exit in the water a good six to eight inches when underway.I am considering raising the location of the thru hull such that the exhaust will be above the waterline at all times, but not sure where to locate it, on the transum or on the hull side. I would appreciate hearing from anyone who has done this, or any discussion, pros or cons. Thanks,Ernie
