Does anyone have a fix for the engine doghouse wire. I would like to come up with something that is attached to the wire and bulkhead that keeps the wire from resting on the top of the engine when it is closed. I loop mine around the overflow reservoir for the freshwater coolant that is mounted on the bulkhead. This keeps it off the motor, but you must be careful when opening the doghouse to remember to un loop it or it can stay snagged and thats not good. I'm thinking of crimping something to the line,and then attaching it too the bulkhead, but was wondering if someone has already solved this problem and can recommend a good material.
d
d
