Engine cooling system and shaft seal retrofit
Bill Welsch
Many of us who own 350's numbered between 1 and 201 have received our Engineering Bulletin 69 kit from Catalina which includes a device to prevent sea water from causing engine damage. Although detailed instructions are included, I'm not sure anyone but an engineer or a skilled boat mechanic should take this on. This poses special challenges for those of us who are are not fortunate enough to live near a boatyard capable of doing such a project. Wondered what others out there are doing to address this issue. Thanks Bill Welsch Punta Gorda, FL
Oct 31, 2005
21
Catalina 350 Brunswick Landing Marina, Brunswick, GA
350 Bulletin
Bill... There has been some general discussion re this subject on the Catalina 350 International Web Site. U might want to post there, also.
Dec 2, 2003
392
Catalina 350 Seattle
Waiting for the boatshow lull
My kit - a rather intimidating 1+ cubic foot box of parts - is sitting in my office waiting for the lull after the Seattle Boat Show in order to discuss with various folks the schedule and cost to accommodate the work required. I also have the original "pss high speed shaft" upgrade to be installed. Frankly, I feel more comfortable installing the latest kit (the vacuum breaker plumbing) than I do the original upgrade kit - which involves moving the shaft and possibly allowing water into the boat. Anyway, it's on the spring list of things to do - right after I go sailing....... Tim Brogan April IV C350 #68 Seattle
H
Hans Grasman
C350 Engineering bulletin
I agree with Bill that the second "important" retrofit should be handled by Catalina,a dealer or other Catalina assigned contractor. I messed up on the first engine retrofit when I broke a set screw in the flange and still do not have it fixed. I also think that $165. does not cut it. I know that I have to haul my boat to fix the situation. Hans Grasman Belcourt #165
