David Revill
I have a 1981 C30 with a 5411 Universal diesel engine. The retaining ring that locates the engine control mounted to the port cockpit riser is badly corroded and I need to obtain or make replacement parts. The threaded retaining ring is corroded beyond use and also a spacer, that looks like it's made from aluminum that is screwed to the riser and bears on the inside edge of the gear shift lever is also corroded and crumbling. The engine control mechanism itself is in good condition. I cannot see a model number or manufacturer for the control and am unable to locate a similar part in the Teleflex Morse catalog. Can anyone let me know the name of the manufacturer and where I may get replacement parts from?Help appreciated.
