Tom, I'm no expert and Geoff certainly knows more then I do. My understanding is that the mixing elbow is where the exhaust gases and cooling water mix before they enter the exhaust discharge hose. The elbow is on the rear of the heat exchanger (on my Yanmar). If this was restricted would it cause the engine to overload? Geoff, your thoughts? Walt To:
AlbinVega@yahoogroups.comFrom: geoff@...Date: Tue, 1 Apr 2014 16:56:52 +0100Subject: Re: [AlbinVega] Re: Engine burn out
Tom, Group,I am a little perplexed about this business of "soot" and "engine burnout". I spent a number of years in the development and testing of diesel engine fuel injection systems and black smoke/soot is a sign of overload such as would occur if the engine is over-propped. In the case of the engines that I worked on - between 40 and 2000hp. the maximum fuel stop would be set up that there would be little/no smoke in the exhaust, indeed the obscuration of the exhaust was a way of measuring the fuelling level.
Many diesels would have an excess fuel control which allowed excess fuelling whilst starting, including some small craft Volvo engines, but normally fuelling would be limited below the level of noticeable black smoke, indeed, if road vehicles emitted such levels of smoke/soot, the driver would be prosecuted under the Construction and Use Regulations. However, I have never known reasonable "over-fuelling" to cause damage to an engine and in some uses engines are deliberately over-fuelled under certain conditions.
Of course, there is cause and effect, a engine or exhaust system requiring de-coking can cause black smoke as will a partial blockage in the air intake side but other colours of smoke indicate different problems.
I have not studied the fuel injection system on the small Beta Diesels to see if they have a "proper" fuel injection system, but I know that certain small engines have very simple injection pumps.
Geoff#################################################Geoff Blake, G8GNZ JO01fq: Chelmsford, Essex, UKgeoff@... or melecerties@...
Using Linux: Ubuntu 11.04 on Intel or Debian on UltraSparcand Apple OS X 10.8.2 Mountain Lion on my Macbook Pro. Avoiding Micro$oft like the plague.#################################################
