Engine blower
Don764
May 29, 2004
10
Hunter 306 Barnegat
I have an O'Day 272 with a Westerbeak 10Twoc diesel. No engine blower or vent lines were ever installed. Should I bother installing a blower and vent lines? Looking for some advice.
May 28, 2004
175
Oday Widgeon Beech Bluff, Tn.
Morning Don
I'm assuming that there is a switch on the ignition panel that has you curious if not, bear with me. Quiet a few of the older boats were using a common ignition panel that were used on diesel and gasoline engine boats. The blower was primarily for gasoline engined boats to exhaust any gas fumes that might exist prior to cranking the engine and blowing the boat up. Diesel fumes if any are not flammable, therefore, a blower was not necessary and the switch is not hooked up to anything, just there. Do you need to exhaust the engine compartment, no, but you can if you want to, won't hurt anything.
