I now own an 1985 Oday 26 with a 1GM10 inboard. any information on the engine would be appricated @ rpm, repair issues etc.
I would also like to know the proper tuning process and specs for the mast tuning. Thanks
O'day made rigging easy. You plumb the mast with the fore and back stay and the two outer shroud, then make sure the mast is straight with the inner shouds.
Then they all get tightened so there is about an inch of play with moderate tension about 4' about the deck.
It has worked for me for 10+ years.
Attached is the 25 spec. http://oday.sailboatowners.com/index.php?option=com_mtree&task=viewlink&link_id=6594&Itemid=222
Hope this helps.
r.w.landau
