Hi - I was wondering if it would be ok to do the following at the same time :
- run engine to charge batteries
- also run shore power charger (via generator) to also charge same battery bank
The shore power charger is a 60 amp unit, and the Yanmar 3xM30 has the stock (50? ) amp alternator
This all feeds into a 450AH bank of Trojans.
Would running both at the same time result in 60 + 50 amps charge current ? (Less the inefficiencies of hot alternator, voltage regulators, etc) - but basically will this give me a faster charge, or cause problems ?
25% charge acceptance rate of the bank should mean it can take 112 amps - but do the 2 sources combine or not ?
Thanks !
(If I gotta listen to the engine, then listening to the genny at the same time makes sense if it reduces overall charge time)
Thanks !
