Engine Alarm
FredW
Sep 8, 2010
7
Beneteau Oceanis 34 Severna Park
My engine alarm starts a few seconds after starting the engine. It would shut off normally , but no longer. All fluid levels are good. Engine does not appear to be over heated. I do not know of any alarm cut off either to temporarily silence it.
Thoughts? Recommendations?
Nov 6, 2006
10,116
Determine whether it is an oil pressure alarm or an overheat alarm. Carefully disconnect one and start the engine.. if it still alarms, reconnect that one and disconnect the other one.. It is not unusual for an oil pressure switch to fail and start sounding a false alarm; do not assume it is bad and leave it disconnected .. a mechanic can check the oil pressure and verify or, if it is the oil pressure switch, you can buy one and replace it .. Same with the temperature switch easy to replace and fairly inexpensive. Some engine panels have a battery charge alarm .. if that is the case and yours is sounding, check that all the belts are tight .. if they are, then its time to use a voltmeter to check that side of the system. You should see above 13 Volts DC if the alternator is working.. Good Luck
DO not assume it is bad and leave it disconnected.
:yikes:
:plus:
To verify the oil pressure, a mechanic (or you) can attach a separate oil pressure gauge to the engine.
