ENGINE ADVICE NEEDED
C
CONRAD OBER
I have an older Hunter 27 ft. sloop, powered by a Renault 8hp single cylinder diesel. The engine is shot. I need suggestions on a replacement engine, size, make & source. Thanks, Conrad
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Renault replacement
Conrad, There is realy only one engine that is a good replacement for the RC8. The Yanmar 1GM10. Pat McCartin Inland Marine Diesel Buford, Ga imd_ga@hotmail.com
A
Andre K
Replace it with Yanmar
I used to have a Yanmar 9hp (!GM10) on my previous boat and I loved it! Never had any problems with it, it would easily start after winter storage. The boat was sitting on the dry for 3 years befor I bought her and it also started "on the first try". So the answer to your question is easy - go with Yanmar! Good luck. Y au may also find a used one out there.
Jun 3, 2004
275
- - USA
Add an Outboard bracket
Properly installed a new motor may cost more than that boat is worth. Depending on your usage an outboard may need your needs
Mar 28, 2004
73
Hunter 27_75-84 Meg n Kate
I have a 1981 Hunter 27
I also had a RC8. I put in a new motor a little over a year ago. I shopped around and paid $4,600.00 for a new Vetus twin 16 HP diesel. Best thing I ever did. It's a great engine and all the power you will ever need for a H27. Also I checked with H&H prop, gave them the RPMs as stated in the Manuel and they told me the prop on the boat was OK. That saved me some $$$ too. The engine will fit with some minor adjustments. I used the old motor mount plates but had to turned them up side down. The same holes that were drilled through the fiberglass were used. The lower back corners of the angle iron had to be trimmed a little because the corner of the angle iron was hitting the floor and we needed to lengthen them a little because the motor mounts on the Vetus were wider apart. Other than that this engine will hook up without too much problem. I did have to raise the steps up one inch and bring them back one inch. I did this by attaching a block of teak wood to the floor at the bottom of the steps. If your not sure how to line up the motor on the shaft have someone do it for you. I had someone help me with it and paid him about $700.00 (He also did some other stuff for me too. Anyway if your boat is in good shape and you like it don’t let people scare you. It was the best thing I ever did for my boat. In stead of the old noisy vibrating beast that was in her. She’s quiet, smooth, and will cruise at hull speed very easily. Its like having a completely different boat.
