Energy Audit
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Looking to "power up" my boat, buy batteries and thinking solar charger but not sure how to do an energy audit when I'm not sure what my usage is goin gto be...?
Weekend crusier, sitting on trailer at marina during the week so not alot of "shore power" to charge off of unless I spend the night in a transient slip...(which I probably will do one night a weekend)
No TV no AC, probably no heater (unless is slip) only "major" usage is I will have a 12 v 75 watt coffee maker for a pot or two in the morning...
Other than that not much draw, beside anchor light one maybe two nights, 10 watt deck light occasionally and basic interior lights... and VHF while crusing and weather reports at night.
I have a pull start outboard so no starter battery needed, so was thinking one (maybe two ??) average size deepcycle batterys and a 10 watt solar panel to recharge during the week (might be two weeks between weekends)...
My impression is with that low a panel a regulator/controler was not neccessary, but I don't want to cook the batterys but I do want them charged up for the weekend excursion...
Am I in the ballpark or am I missing some commonly used appliances that I should add to audit...?
Jun 17, 2007
402
MacGregor Mac26S Victoria Tx
My case is similar to yours. I went with 2 AGM's (don't have to be AGM's) and went with a 20w solar panel. A controller is recommend. I also found the 20w panel gives me a bit more cruising range. I also have a ventilation fan that runs 24hrs 7day a week. (draw .08a) VHF, GPS, instruments, auto tiller pilot, fan. I usually run off one battery the first day, then switch to the second one the next day (first still has some reserve and panel is charging it while using the second battery) Third day I still have power without having to head to a marina for power.
I developed a solar panel that attaches easily to a railing and easily adjustable. I plan on putting them in production soon.
May 24, 2004
7,215
CC 30 South Florida
A controller is recommended as it will prevent battery power from leaking back into the panel at night.
Beneteau 323 Annapolis MD
The "Boatowner's Illustrated Electrical Handbook" offers that if your panel is less than .5 percent (in amps) of the battery Ah rating, you do not need a controller. (2 amps panel in a 400-ah bank).
West says 1.5 percent. (1.5 amp panel on a 100- amp battery.)
Squidd
Sep 26, 2011
890
OK....10 watt panel has .59 amp rating... sounds like I'll be safe with a 100+/- amp battery and diode to prevent drain...
Feb 6, 1998
11,760
A french press might be a good energy saver..
Listening to the VHF is low draw. The lighting will be your biggie and cold be +/- 10 Ah's per day.
If you can fit a couple of deep cycle group 27's you'll have about 180 +/- Ah's depending upon brand. A 10W solar panel is a "maintainer" not a "charger"...
A general rule is that any panel that does not need a charge controller is also a panel that is not a charger but rather one that basically maintains your state of charge and not much more.
A 10W monocrystaline rigid panel can put out roughly 0.55A. At an average of abuot 5 hours per day at max output (usually less if panels can't be "aimed") you'll get about 2.75Ah's returned per day, at best. If you're using 10 Ah's per day, which is quite light with incandescent bulbs and a 75W coffee maker, you're still consuming 3X the energy than you're putting back per day.
When shopping for panels look at the (Max Power Current / lmp) rating and multiply that times 5. That is roughly what the panel can return in optimum conditions per day.
With a 180Ah bank down 30 Ah's (roughly 84% state of charge) it would take you 10.9 sunny clear days to get back to full. Though this is straight math and does not account for charge inefficiencies, parasitic loads and natural self discharge. In reality you're looking at about 12+ days to get back to full from an 84% state of charge. That is a panel which is far to small for weekending...
Mar 19, 2011
225
Catalina C25 Eagle Mountain Lake
One of the best things I've done to my boat is replace all the cabin lights with LED's. I have 5 lights in the cabin. The previous incandescent bulbs would draw 1.4 aH each...the new LED's are brighter and draw .09 aH each. I can light the whole boat for less than half the cost of 1 incandescent bulb.
Squidd
Sep 26, 2011
890
Good info thanks.. will continue on calculating amp "budget" for a normal weekend and look into larger panels to keep up and maintain charge...which will then put me into controller territory...
Squidd
Sep 26, 2011
890
So what is the wattage on a basic 1970s incandecent bulb....? (Looks like automotive 2 prong) ~ 15 watt??
Jun 6, 2006
6,990
Check the downloads section. there is a spreadsheet the takes a lot of the toil out of dong and energy budget.
Squidd
Sep 26, 2011
890
Up in "resorces"...? I hit downloads and get a "Not Found" error 404
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
Squidd, get rid of the coffee maker. I had one, used it once and it drained the battery to the point that I couldn't start the engine (long time ago, different boat with only one battery and me being very "green" about my energy setup). Get a percolator. I love making coffee and enjoy the ritual every morning on board.
Dec 2, 1999
15,184
Squidd, get rid of the coffee maker. Get a percolator. I love making coffee and enjoy the ritual every morning on board.
A melitta works well. Get an insulated caraf and it will keep your coffee hot for several hours.
Do a search on coffee on this board or any other one, and you'll have enough to read for weeks. :):):)
Squidd
Sep 26, 2011
890
How did you get it to work Squidd?
Actually went to one of the other headings under the resorces tab ("library" I think) which opened.... and then from there back to resorces tab and then "downloads" and it opened up...
Squidd
Sep 26, 2011
890
Yeah, the coffee pot is outah there...
I opened the box and the draw on the bottom is actually 12v 200 watts... then I filled it with water and pluged it in out in my truck ...24-30 minutes for 4 cups...
While not too much juice for a weekender way too long to wait for coffee in the morning...
