A
Aldi
1. I just did a hose line upgrade to the engine. Last sunday we took the boat out and about 30 minutes it died. I tried to restart and it would keep running for a while and then die. I am not sure if the air in the fuel line is the reason or not? How it all started was that i stopped the boat and wanted to practise some reverse manuvers, and after that it all went down hill. Anyideas or suggestions. I checked that i had fuel and the tank was 3/4 full. Does anyone know if I should use a more powerful fuel pump? Any suggestions will be appreciated.2. The second question is that i noticed the propeller shaft was spining while in neutral. Is that normal or is there something wrong with it? I have an Atomic4 and don't know much about it? should i hire a mechanic to check it out?
