emergency tiller
Jim
I need to get an emergency tiller for my boat. I don't know were to go.I have a 1988 Catalina 30. Some direction would be helpful, thanks.Could you tell me what it looks like?
Where to go
It's a Catalina. Catalina is still in business. Why not try Catalina?
Tony Carlisle
Catalina Direct
Try Catalina Direct 800-959-7245. Great folks. Fast and knowledgable.
Don Guillette
Emergancy Tiller
Jim: Stu is probably right - try Catalina or Catalina Direct. This is for Catalina owners out there that have not tried their emergancy tiller in a practice situation. It is a small, stubby little thing but it won't work with the wheel in place. To try to loosen the wheel nut in a emergancy situation and find it is too tight to get off, especially if you have never had it off, is not a good idea. Take a few minutes the next time your at the dock and loosen the nut so your sure you can remove it should you have to in an emergancy. At least you'll know what size wrench you'll need and where it is.
Jim Hamilton
Wheel Nut
The wheel nut on my Cat '30 was pretty much corroded on. (the boat is new to me) So I removed it, cleaned the corrosion and applied some anti-seize grease to the wheel and installed a quick release nut that I bought from Edson. The 'nut' is a round one built to go on and off by hand. Now removing my wheel takes 2 seconds. (better safe than sorry!) I also bought a mounting piece to mount the wheel on the safety rail on the back of the boat. Now when I'm moving around in the cockpit and am not going anywhere, I mount the wheel on the back of the boat and that frees up a LOT of room in the cockpit. Don't remember the cost...I think the nut/mounting piece combo was $90. The nut itself is $40-45. Jim
