Well, we took the next step forward and ordered the serpentine belt kit for the Universal M-25 from Electromaax. Wouldn't you know it...it did not directly fit our crankshaft pulley (ours is not tapped to bolt the new pulley on it). So after discussing options with EM, I sent them my crank pulley and they are going to mold/mill a replacement pulley. Once I get it back and installed, I will post the results.
John at EM said they will set up a mold to make additional ones as people need it, so if you are contemplating the upgrade, give them a call. I have attached a picture or our crank pulley and the original "replacement" pulley.
Lastly, if you do go to remove the pulley, the retaining nut requires a 29MM axle socket. My dewalt rechargable impact wrench made quick work of removing the nut without damaging the shaft, or my knuckles.
