Recently received a Hunter edge 27 with the 75hp Everude. Very happy, BUT! After only 12 weeks, resting in the Med (Barcelona) the outboard mounting bracket and piston reservoir has corroded to a very worrying condition, having lost about 6mm of alloy on these components and can no longer raise motor!
Will replace the failing bits, but obviously, cannot afford to do this too often.
Advice someone?
For your information. When in harbour she's connected to a mains supply. The boats bottom has been copper coated. The Med has very high saline level.
Have e-mailed Hunter and Everude. But have not received a reply.
Advice someone?
