Bill, do you have neighboring boats that are plugged in all the time? Are you in a marina or do you have your own dock? Have you considered unplugging your boat for awhile and seeing what happens? Do you have Calder's Boatowners Manual? He has a very good writeup of the options you can examine.
Good luck.
Boat is in my back yard. I'm the only boat in my canal plugged in all the time. I have the only boat lift for 4 or 5 hundred feet, but there is an underwater light two houses down. Off in the daytime, but still in the water.
Have Calder's book, will re study, but when I disconnected the grounds on all seven batteries,with no change in voltage or ampearage, I was stumped.
Will again try turning off breakers in my house, disconnecting shore power,but last time i did all that, I still had volatge differential.
